Alwan problems
We are having a problem with the lwan Color Server.
I have a pdf file that is 96 pages and about 975 megs. It errors when I try to optimize it. If I extract the pages and run 96 single pages they all optimize. The file in the finder is 975 megs but when looking at it in the job manager it is a hair over a gig to alwan.
Intel Macintosh 10.52, 3 gigs ram, 115 gigs hardrive free. I updated from Alwan 3.01 to 3.1 and still a problem
Mike
Also I have found the same problem.
The problem become from a memory limit (pool of ram) of MacOSX and the PDF lib on which Alwan work.
More than 2 giga do not work.
Regards
I also heard this was a problem that was fixed in Leapord
My config is Leapord 10.52 Intel Macintosh, 3 gigs Ram 115 gigs hardrive free
probably no, as I had this problem in a test suite last week.
The problems seems the Adobe PDF library.
Alwan said 3.2 fixes these problems
Not out yet so will struggle till this happens
