Blend Gray Samples option
Curve 2.1 has - added “Blend Gray Samples” option which invokes pinwheel averaging if desired. Saves & loads from doc as well.
Please explain what pinwheel averaging is and provide an example when it would be useful to turn on.
Matt Louis
The Blend Gray Samples checkbox will provide a special kind of proprietary smoothing. If you have a well-behaved printer you should not have need for this under normal circumstances. This is more intended for the situation where you’ve had erratic printing of your targets (or measurements) and you can’t go back and print a better run. This checkbox will smooth out erratic printing or measuring to make your curves slightly better in a bad situation.
We had the ability to add this function so we did. But it is not intended for normal use, and that is why it is off by default.
