Hello, trying to understand can I get curve3 curves in form of density?
I would like to linearize a small format rip
The linearization should I say ink limiting is set like this after measuring straight curve printout for every channel.
The minimum max ink is set separately, and should not be changed:
1.I thought I could use curve3 to enter the measured values and that should make grayscale neutral right?
What about light channels, curve 3 provides curves only for CMYK channels?
How to get curves in form of density values ?
