Color Management about CMYK Status-A, E, M, T, type1, type2
Dear Master
I only have a CGATS file that includes CMYK, Lab and spectra values.
Q1)Can I use these values to calculate Status-A, E, M, T, type1, type2 and Visual values?
Q2)Can I use these values to calculate dot gain value?
Q3)where can I find these formulas for Status-A, E, M, T, type1, type2 and Visual?
Thanks for helping
To get density information from spectral data, there are some calculators on Bruce Lindbloom’s site that should work for this:
brucelindbloom.com/index.htm … lator.html
If you’re measuring with the i1Pro instrument, you’d want to get the 10nm version.
That’s a useful site. If you poke around there some more you can probably find the formulas for these there.
Dear Master,
I try to figure out these questions via brucelindbloom.com/index.htm … lator.html
But this example is only for RGB. So I don’t have any ideas about CMYK.
another question:
Does these spectral data values in CGATS file are density refraction?
Thanks for Helping
Sorry for the delayed response.
The spectral values in a CGATS file are percentage reflectance (typically expressed as decimal values in the 0 - 1 range).
Density values can be calculated from spectral values but they are not the same beast.
Hope this helps.
