ColorThink Beta 2.2b16 - Single Color mode problem (small)
Problem: If I click the colors ‘orange,’ ‘pink,’ ‘white,’ or ‘black’ when in Single-Color display mode the screen doesn’t refresh with those new colors. One way around it is to go up to the ‘plot items’ palette and toggle the check box for the affected profile off and back on.
Also, there are problems when selecting ‘orange,’ ‘pink,’ ‘white,’ or ‘black’ first. There’s something up with those 4 colors.
Repeatability: 100%
Primary Steps to Repeat:
Open one or more CMYK or an RGB profiles in 3-D view
Select ‘Single Color’ in the ‘Plot Color’ palette.
Select any of the colors up through purple.
– Everything works normal up to this point
NOW, select one of the bottom 4 colors and you will see the problem (hopefully).
Alternate way to show problem:
Steps to Repeat:
Select any of the bottom 4 colors.
The display may not refresh correctly, or you will not be able to select any new colors - even those that work correctly when following the primary steps.
Mac Dual 2.5Ghz G5 - ATI RADEON 9600 XT Graphics Card
At 6:28 AM -0700 9/19/05, richardbrackin wrote:
Problem: If I click the colors ‘orange,’ ‘pink,’ ‘white,’ or ‘black’ when in Single-Color display mode the screen doesn’t refresh with those new colors. One way around it is to go up to the ‘plot items’ palette and toggle the check box off and back on.
Repeatability: 100%
Steps to Repeat:
interesting one… yes, I can repeat it here
thanks for the feedback
