ColorThink Pro - Color Worksheet Questions
I’m still in tinkering around mode but I need some clarification:
The manual says “For the purposes of speed and memory use, large images are down-sampled as they are opened.”
What is considered large? Is it a moving target based on the amount of RAM installed on the machine? Is it set in stone to a particular pixel count?
Example: I opened an 8bit TIF file that is from an 8 megapixel digital camera. Storage size is 24,016.5 KB (disk), 975.6KB (ram). 333 x 500 = 166,500 pixels.
When I convert all colors to list, I get 166,500 colors. When I convert unique colors in this particular image, I get 27,991 colors. Also, I’m not entirely sure what the ‘name’ means out beside the color number. It’s also a number.
When it counts unique colors, does it look at the full size image or does it take this downsampled version and count colors?
… and does it make a difference counting color from the original vs. counting colors from a downsampled version?
This sounds awesome!! I can’t wait to try this one out. I may need some hand holding, though. I have a few questions about this that I am not sure how to ask yet.
set in stone at the moment. RGB images that are over 500 pixels on their largest side are down-sampled to 500 on that side (and whatever makes sense on the smaller side)
right, that looks to be about in line.
OK, sounds good.
at the moment it looks at the down-sampled version. This is mostly for speed.
I am certainly open to other ideas. I am working either a dynamic down-sampling or a user-selectable level (or both). It is plain to see that downsampling is necessary for images above a certain size as it slows the machine to a crawl. ColorThink is typically saving 3 versions of each image (or each image ‘version’ in a workflow) for each one you see on screen. This means it uses many more times the amount of memory than a normal imaging application like Photoshop might (although PS can certainly get up there with layers, etc).
[quote:9c1a75988b]
Creating Custom Targets from image data…
[/quote:9c1a75988b]
fair enough.
The simple flow is this:
  • open an image you are having trouble with
  • apply the output profile to it if it is not yet in the output color space.
  • select the Target Marquee tool and choose “custom”
  • set the number of patches you want selected.
  • click-drag on the image to select the range of the image you want sampled.
ColorThink will pull the sample points out into a list.
  • then select “use as primary list” from the color list’s popup menu and CT will replace the image with a target of the sampled colors.
that’s it! You can then save the color list device values and formulate them into a target using your favorite target software (ProfileMaker or ColorPort most likely) and you can either use it as a target for sampling or to augment your existing profiling targets (Profilemaker supports this but Monaco Profiler doesn’t).
Hope that helps…
This is the very sort of operation that I can build into a Guide for easier access & learning. If you come across things you do a lot that you would like automated let me know and I’ll see if we can create a Guide for them.
ahhh. That’s why I’ve seen Chromix using 1.7GB RAM in the activity monitor. :slight_smile:
Thank you for the detailed information, Steve.
About the Custom Targets:
I use Monaco Profiler so I guess I’m out of luck with that feature for now.
