I have just recently installed Curve2 v2.1 on Windows XP Pro and when I try to start Curve2 v2.1, I get the following errors and it will not load up:
"Runtime Error
Press OK to Continue
Press Cancel to Quit.
Please report what caused this error
along with the information below.
…\Common\plugin.ccp: 7280
Failure Condition: pluginEntry Table.GetEntry(entrypointName, out)
can’t find plugin method CDML TableMBS.set(col as integer, row as integer, width as integer, height as integer, text as string) as CDTextBoxMBS"
It worked the first time opening, right after install and then after that, will not open again. We have uninstalled and re-installed with no luck.
Any and all help will be greatly appriciated.
