Hello all, hoping to get some kind help & advice…
I have a dual monitor setup and need to get them both calibrated so that they are at least close to each other. I’m not doing the kind of graphics work that requires any real strict control over color.
I’d just like my two monitors to look pretty decent, or at least similar, side-by-side.
Setup:
Mac (OS 10.4.11) with an ATI Radeon 9200 and dual monitors
LCD #1
26" Samsung SyncMaster 2693HM - via DVI
(brightness/contrast control - no backlight control)
LCD #2
19" Samsung SyncMaster 914v - via VGA
Issues:
LCD #1 - 26" Samsung is very bright out of the box. So blinding that it actually hurts the eyes. Using native settings this monitor looks very cold & blue sitting next to the LCD #2.
LCD #2 - 19" Samsung is a pretty good display with normal brightness but looks too warm & red sitting next to LCD 1.
Calibration:
I obtained a Spyder2pro to get these two in line with each. There is no procedure given at Datavision for the Spyder2 for a dual monitor setup so I’ve been “winging it” here.
I’m selecting a 1.8 gamma (Mac) and a 6500K white point for calibration. I’m also manually selecting the white and black luminance values. Then also using the RGB controls on the monitors along with the Spyder2pro software.
White Luminance
Adjusted mainly via Contrast Control but also affected by RGB Controls
Since LCD #2 is darker, I use the Colorimeter to take a reading of white and get the max white luminance value. It reads 135 but when RGB values are later adjusted, it drops quite a bit.
Over at LCD #1… since it’s so bright, white luminance is in the 375+ range. However, it’s nearly impossible to adjust this lower than 110.
I can’t get higher than 125 on LCD #2 and can’t get any lower than 110 on LCD#1, so I settled on a white luminance target of 120 for both.
Black Luminance
Adjusted mainly via Brightness Control
I do not quite understand the Spyder2pro software in this regard. When you select “manual”, it asks you to enter a value for both black & white luminance yet for whatever reason, it always ignores what I enter for black and over-rides with 0.30
Whatever… this is a value that is totally impossible to achieve on the 26" Samsung. The lowest I was able to get it was 0.38 or so. Trying to obtain the same value on BOTH monitors, I’ve had to settle for a value near 0.44.
RGB Controls
So then I proceed to carefully follow the software’s procedure. Both monitors set to luminance of 0.44 and 120 and RGB adjusted to obtain a 1.8 gamma and 6500K white point. According to the Colorvision “info” tool, I’m doing an excellent job with a delta value consistently less than 1 on both monitors.
Problem:
Why does it only look a tiny little bit better? Each monitor by itself looks fine but next to each the original problem is now flipped over as if I passed through the ideal setting. LCD #1 started off blue compared to #2 and now it’s redder compared to #2. LCD#2 started off too red and now it’s yellow/bluer than #1.
I’m on the right track since calibration made such a noticeable difference but why can’t I get them to match close enough to fool the eye?
After calibration, I’m hesitant to make any tweaks since that defeats the whole purpose of calibrating. On the other hand, the whole purpose of calibrating is to get both monitors to look the same side-by-side and after about a dozen failed attempts, I’m exhausted.
Can I use the Colorimeter to make additional manual adjustments? If so, what? How?
At first I thought that these two monitors were just so radically different I was trying to do the impossible. But I don’t think so. I made the cold one warmer and the warm one cooler so someplace in between is where I would want to be.
I’ve even tried setting a lower white-point of 5800K on LCD #2 but that looked totally ridiculous next to a monitor calibrated at 6500K.
I don’t think there’s a problem with the USB connection or the Spyder device itself as multiple readings are consistent with each other. Also, I’ve performed the same procedure multiple times and get the same or similar results each time when all inputs are the same.
No direct sunlight, north facing windows 15 feet away, two 75 W incandescent ceiling bulbs, and direct Spyder contact with screen and LCD baffle installed. Also tried calibrating in dark room at night with same results. (not using “ambient light compensation” in either case)
Any suggestions are appreciated.
Thank-you!
