Actually the i1 Xtreme is called “extreme” because it offers just about everything. You get the RGB easy and CMYK easy - as well as the “full” targets also. The built-in RGB target is the 918-patch, and the CMYK target has over 1400 patches. We also know of work arounds to use other (larger) targets if you want to.
Xrite has recently simplified the line to just include:
I always thought the profile editor for under $100 was a neat little deal. It can’t dial in on specific colors like the more professional profile editors, but it does a good job with any kind of general color adjustments.
Thanks I did see that option although I was hopping that there might be a bundle upgrade. I guess not from your reply.
It would be helpful if you were to update your comparison page to include both the new and old packages so that it is easier to understand the differences.
Yes and yes. With i1XTreme you can create ‘Easy’ profiles (which are the quicker and shorter targets) and Full profiles (using the full RGB or CMYK targets). This is a great intermediate package that creates profiles for every device in your workflow. i1XTreme includes many things including a spectrophotometer instrument. For more information: <http://www2.chromix.com/colorgear/shop/productdetail.cxsa?toolid=50072&pid=10449>
anyway, does the 2 models of i1Xtreme have 2 different function/use? or does the UV CUT model have the feature of the non-UV CUT? Because the price difference is not big, might as well get the model that can do both, if ever.
ProfileMaker doesn’t “cut” the uv per se, but applies some proprietery compensation when a “bump” in the blue area of the spectrum is detected, which would usually indicate the presence of optical brighteners. Note that this compensation is applied only to the perceptual rendering intent. Its results can be significantly different than uv cut filtration, which prevents the excitation of the optical brighteners to begin with.
If you’ve got serious issues with optical brighteners, you might consider an isis with OBC, or if you like to tinker with Terminal, the Argyl CMS (which is free, but no user interface yet).
I’m probably making this more complicated for you. I’m not a fan of uv cut filtration, but everyone has to make their own decision here.
anyway, We mostly print on Dye-based ink printers, and we usually laminate our prints, does this mean we should laminate our prints first (linearizations tables, swatches, etc.) when doing our calibration via the i1Xtreme?
Since you’re interested in the color results of your final product, you should generally go ahead and laminate your profiling target, and make your profile reading that.
As for laminating your linearization target, I can see good reasons for doing it either way, but it’s probably not necessary.
You need to check your computer for spyware or a trojan horse. Your posts are being edited by something on your computer… Take a look below. You also may be inadvertently spreading something.
