Hello everyone,
Before I calibrate the monitors, printers and scanners, I thought I would ask some experts for advice. Are there any issues about calibrating several monitors on a network that I need to know, I’m concerned about having to turn off my antivirus software, is this just for initial calibration and can I then switch it back on?
If anybody has experience of calibration over a network I’d appreciate some advice.
Hello everyone,
I don’t think you’ll have problems with it… your mileage may vary.
I suppose you should supply a little more information. Are you using a product that actually supports network-based calibration or are you running the software from a server or…
