Hi -
I’m new here, and not sure if this thread is in the right spot ;p
I have a job to design for litho printing… but the client has given me NCS colour values which i now need to convert to CMYK…
HELP!!!
Thanks … I hope someone has some advice here!
I suppose the Color Science forum would be the correct one to use - but no worries, this will do.
I did a quick search in Wikipedia and found an article on NCS with some external links, including calculators and a viewer for NCS color:
http://www.i2studios.com/index.php?Page=http://www.i2studios.com/ncs/
This should at least allow you to convert to RGB values, and from there you can define what kind of RGB you’re using and convert to a certain flavor of CMYK using Photoshop or ColorPicker.
