louie
April 20, 2010, 4:40pm
1
I was looking over my documents and found the original calibration page that was shipped with my instrument. It recommends that I should have the i1Pro re-calibrated after about 2 years. My instrument is about 5 years old now.
What is your recommendation regarding re-calibration? How can you tell if it is needed? My instrument is always stored in in the padded case except when in use.
tks, louie
smile
April 20, 2010, 10:18pm
2
Use i1Diagnostics v2.5.1 to check your i1Pro.
You can post the result log file here for diagnosis.
Download here:
xrite.com/product_overview.a … wareID=506
louie
May 3, 2010, 5:30pm
3
Here is the log file output from i1Diagnostics. Please take a look and see if there is any indication that I should recalibrate.
tks, louie
General Information
Date and Time: 5/3/10 11:31 AM
Application version: Version 2.5.1
SDK version i1: Version 3.4.0 Build 131
SDK version iO: Version 1.1.2 Build 100
SDK version iSis: Version 1.0.5 Build 70
Platform: Apple Mac OS X 10.5.8 (9L31a) i386
Device Information
Device type: i1Pro (NO filter) [ Ambient Light Emission Reflectance Reflectance Scan Flash ]
Serial number: 125689
Firmware version: 302
CPLD version: 301
Dark measurement count: 7536
Lamp burning time: 7243.59 seconds
Spot measurement count: 617
Scan measurement count: 1312
Dongle Test
Module "Scanner" is licensed
Module "Monitor" is licensed
Module "Printer" is not licensed
Module "Printer RGB only" is licensed
Module "Printer CMYK only" is not licensed
Module "Beamer" is licensed
Module "Printer Easy RGB" is licensed
Module "Printer Easy CMYK" is licensed
Module "Digicam" is licensed
Module "Editor" is licensed
Button Test
Button is working normally
Calibration
Emission calibration: Successful
Emission Test
White measurement: Successful
Gray measurement: Successful
Black measurement: Successful
Red measurement: Successful
Green measurement: Successful
Blue measurement: Successful
Emission Test: Pass
Dark measurement
Dark measurement: Pass
Noise Measurement
Noise measurement: Pass
Lamp test
Reflectance calibration: Successful
Reflectance measurement: Successful
Check measurement result: Successful
Reflectance Test
Reflectance spot test: Successful
Scanning calibration: Successful
Reflectance scan test: Successful
Measurement 1: Successful
Measurement 2: Successful
Measurement 3: Successful
Measurement 4: Successful
Measurement 5: Successful
Measurement 6: Successful
Measurement 7: Successful
Measurement 8: Successful
Measurement 9: Successful
Measurement 10: Successful
Reflectance drift test: Pass
*** PASS ***
General Information
Device Information
CPLD version: 301
Dongle Test
Button Test
Calibration
Emission Test
White measurement: Successful (X=77.768 Y=82.087 Z=88.081)
Gray measurement: Successful (X=28.928 Y=30.439 Z=34.183)
Black measurement: Successful (X=-0.094 Y=-0.035 Z=0.047)
Red measurement: Successful (X=46.700 Y=22.946 Z=1.134)
Green measurement: Successful (X=15.671 Y=49.901 Z=6.860)
Blue measurement: Successful (X=15.078 Y=8.853 Z=79.833)
Emission Test: Pass
Dark measurement
Dark measurement: Pass (-27.711)
Noise Measurement
Noise measurement: Pass (3.275)
Lamp Test
Reflectance Test
Reflectance spot test: Successful (LOT=7244.25 seconds, CIT=0.01836 seconds, LIT=0.0203884 seconds)
Measurement 1: Successful (L=96.413 a=-0.591 b=2.199)
Measurement 2: Successful (L=96.380 a=-0.584 b=2.225)
Measurement 3: Successful (L=96.352 a=-0.569 b=2.248)
Measurement 4: Successful (L=96.300 a=-0.562 b=2.320)
Measurement 5: Successful (L=96.302 a=-0.578 b=2.323)
Measurement 6: Successful (L=96.303 a=-0.582 b=2.332)
Measurement 7: Successful (L=96.302 a=-0.578 b=2.333)
Measurement 8: Successful (L=96.305 a=-0.589 b=2.342)
Measurement 9: Successful (L=96.282 a=-0.575 b=2.366)
Measurement 10: Successful (L=96.297 a=-0.586 b=2.362)
Reflectance drift test: Pass (0.061)
*** PASS ***
The numbers on your Emission Test seem to be a bit off.
In particular, it looks suspicious to have your Black measurement have negative numbers for X and Y. Gray and Green look pretty different too.
I don’t really know how to interpret the numbers, but your numbers seem to be quite different from mine:
louie
May 5, 2010, 3:06pm
5
Patrick,
I have contacted Xrite support to see what they say about the results of test. I will keep you posted.
tks, louie
Can you tell me exactly what the emissions test is. I just ran i1 diagnostics on my i1 Pro because of some strange behavior in my profiles and it failed the emission test.
An i1Pro device can measure reflective light (light bouncing off of a paper for instance) and emissive light (light emitting from a computer display). The i1Diagnostic program runs the device through its paces on all these functions. The emissive test would not include any self-illumination, so you might try it again and make sure the device is on the screen when it is supposed to be and that it is well-settled in the in the cradle when it is supposed to be.
I ended up sending in the log files. And, it looks like I have a lamp issue. Fortunately the device is still under warranty. Thank you for your quick response.
