I installed 2.2, after having used the betas and the earlier versions, as well. Now when I go to inspect a profile or view it in 2D or 3D, I get an error -2405 message. Any ideas why this is happening?
I can use the manager and medic, and these two aspects of the program run fine.
Thanks—
Chances are pretty good that you are on Windows and it is OpenGL / video driver based.
If I’m right about you using Windows, please download and install the newest video drivers for your graphics card and then give it a go…
regards,
