Luminence Target
I’m using i1 display2 on a fairly new LCD NEC 1980 SXi.
Whether I try easy calibration or advanced, I end up with a current luminence value of about 58 when the target is 140.
Am I missing something in the calibration?
Do I have a monitor problem or calibrator problem?
Actually I’m getting a pretty good match between the screen and the print. Maybe the screen is a tad brighter than the print from an Epson 4000 with the Epson profiles but then I’m one of those people who don’t soft proof.
Any suggestions will be appreciated.
Billie
BILLIE
I sent you direct a series of screen shots how I did it. (the screen
shots will be stripped out of the forum email) I didnt mess with the
lumination so its off a hair because I have my monitor locked but
note I still came within 3 and the tolerance is 5.
Hope this helps
Mike
Mike,
Thanks. I do not get a screen for luminence. I get first a screen for
contrast which I set to 100% and then pull back until I get the “arrows”
to line up.
Next I get to choose the RGB. I use the preset option
Then I get the brightness adjustment screen with i1. Even with my
monitor set at 100% brightness I still end up with a luminence of 58 to
60%. I’ve tried the easy method and the advanced method. Still not
getting anywhere near 140 luminence. I’ve calibrated this monitor
before and I don’t remember having this problem.
Mike Carpenter wrote:
BILLIE
Hope this helps
Mike
Billie
Sent from colorforums.com
To start new topics, do not reply to this message. Cut and paste
the forum address into a new email.
(c)2004-5 CHROMiX, Inc.
