I got a pb with the 3.0.1 beta 23 under Win seven 64 bits.
The beta 23 works correctly under Win seven starter (32 bits), but under 7 64 bits system, the graph window is never displayed !
I tried differents compatibility options but unsuccesfully !
Can you help me ?
Yes,
The latest version of CTP works well if you install it under the 32-bit program files. There should be no problem with graphing.
It will run as a 32-bit program, so you would need to install it under the Program Files folder marked “x86” in your C: drive.
On Aug 1, 2010, at 7:04 AM, pag wrote:
Hi, Thanks for your response.
Unfortunately, CTP is already installed under 32 bits program files and never the graph window is displayed
CTP is unusable for me
