How do I plot by points? All that is available is “volume”
Dennis:
If you’re working with profiles, in the ColorThink Users Manual in the ColorWiki website check out:
<http://www.colorwiki.com/wiki/ColorThink_Pro_-_Grapher#As_Points_2>
If you’re working with images, check out the section right below that called ‘Working with Images and Lists’
That should help.
Rick Hatmaker
On Sep 2, 2010, at 11:01 AM, Dennis DiValerio wrote:
Point and Vectors are grayed out - no selection available. When I tried the demo version they worked, but the purchased version does not. Do I need PRO to get this feature?
Dennis:
What version are you running? You may try a fresh download and re-load.
Otherwise, you might call in to CHROMiX Tech Support and get some troubleshooting help. 206-985-6837 Ext#2.
Rick Hatmaker
On Sep 2, 2010, at 1:27 PM, Dennis DiValerio wrote:
If you’re working with ColorThink Pro, a profile can be plotted as either Points or Volumes. A color list can be plotted as Points or Vectors.
If you’re on ColorThink 2, a profile is plotted with Volume only, and a color list is plotted at Points or Vectors.
