Profiles from charactrization data
1-In Profile Maker, how can I create profiles from charactrization data such as GRACOL?
Any feedback will be apreciated
Faro
Hi Faro,
It should be fairly easy. Go to the Gracol website and download the characterization data sets. Drag it into profilemaker, and it should populate the measurement set area and reference set area automatically.
gracol.org/resources/datasetdownload.asp
From there, you would make your profile using the separations other settings as you like.
