Question about EFI ES-1000
I had purchased a EFI ES-1000 for the purpose of monitors calibration and inkjet printers profiling.
However, I read it off the net that it can do more than that.
Is there any ES-1000 user out there who can teach me how to fully utilise the device?
What is the differences (beside software) between ES-1000 and Gretag Macbeth Eye-One Photo?
Thanks in advanced…
Allan
Allan,
The ES-1000 and the Eye-One Pro are the same instrument. You should be able to do the same with your instrument that can be done with any basic Eye-One Pro.
