Hi all,
My second post in this forum. It is a really good place to learn about color management and I spent plenty, but not enough time reading knowledgeable post in here. Thanks for that!
I do a little bit of printing on my Epson 4880 and I am keen on improving it.
I did couple of profiles using ColorMunki and tried to rename the profiles in ColorThink later on.
I did rename the internal name as well as the file name. I tried to use them later on, but Photoshop and Qimage sees them as corrupted profiles.
Can I sort this out?
You have not mentioned it, but I’m guessing that you have ColorThink 2. Your profiles are made according to ICC spec version 4, and ColorThink 2 has problems displaying names for version 4 profiles. I can’t remember if the ColorMunki has this option, but you could see if you have the option of making version 2 profiles instead. That would solve the problem.
Also, our ColorThink Pro software has no problem renaming version 4 profiles.
Until we come out with an update to ColorThink 2 that will handle this issue correctly, I will offer to anybody out there that I will rename any problem profiles you have. Just send them to me and I’ll change the names as you want them.
Here it is:
We have a bug fix release for ColorThink 2 that should fix these pesky issues.
Version 2.3.1 is the latest version for Mac, and version 2.3.2 is the version for Windows.
