Is it possible to install to and run Colorthink from a flash drive?
Well, it took me awhile to find a computer around here that didn’t have ColorThink on it already so I could test this. But a G3 Mac running 10.3 will run ColorThink 2 from a flashdrive with no apparent problems.
If your system is low on RAM, you might find it running very slowly with this setup.
It is strongly recommended that you copy your preferences folder into the same folder as the ColorThink application when you do this, otherwise you may be breaking your software license with us.
