RYB Complimentary Color Calculations?
Greetings,
Before I query the audience, let me start by explaining what I want to accomplish. I am a web developer, and one of my current projects involves creating a system to help the end-user determine complimentary, split-complimentary, triad, and analogous colors for a given color.
This is quite simple when using the RGB Color Space, because each primary color (as well as secondary) has equal representation (hue range) on the wheel. However, I would like to offer the ability to do the same using the RYB Color Space. However, because it is based off of light wavelength, some colors are more “stretched” and others “compressed” on the palette. Because of this, I can’t think of a concept to make this quantifiable.
Anyone have any ideas?
At 1:30 PM -0700 8/3/05, TheJase wrote:
Greetings,
Check out this link at wikipedia:
http://en.wikipedia.org/wiki/RYB_color_model
The RYB space, while possibly still in use, is considered incorrect and has been replaced with CMY.
I would suggest that you use CMY rather than RYB as it will be easier to use, more correct, and pull users into the correct way of doing things…
On the other hand perhaps you are talking about Magenta, Yellow, Cyan when referring to RYB?
I think the CMY color space is defenitly not equivalent to the RYB one.
Mixing in CMY or CMYK is really strange. For example mixing magenta and yellow gives red. Most people are used to mix in RYB, as they learned it in elementary school.
They are certainly not equivilant, and yes, magenta and yellow yeild red, but with an RYB model, what makes magenta…or cyan? Niether RYB or CMY are perfect, but CMY seems to be a more logical alternative.
I can understand the appeal of the RYB model though…imagine a box of Crayolas with only 3 crayons, plus black. :stuck_out_tongue:
