samsung 213T monitor / anyone profile this monitor?
Just purchased a 213T and Monaco Optix XR. When I try to adjust the monitor color or contrast with the OSD menu the controls are grayed or locked out. Any ideas?
Thanks in advance.
Larry
not sure… they may be locked? (you can sometimes lock settings so users can’t mess with them)
or, it may depend on the mode of the display. If it is in some “preset” mode (like sRGB) then you may not be able to adjust them but if you choose a “user” mode then they may be available…
I was having some other problems with it. Pixels were blinking all over the display and the auto adjust feature did not work. I sent it back for replacement. I guess I got a lemon. Thanks for the reply. If I get another one with the controls locked out I will call Samsung Tech Support.
