Source for plastic "18%" Gray Card
I am looking for something made of plastic - or otherwise durable and permanent.
Many of the modern cards are optically neutral, and are good for white balance - but I am looking for something which is, in addition, a standard gray value, suitable for determining exposure: with light meters, film, etc.
I am already aware of the controversy surrounding 18% versus 12%, etc.
Thanks !
Hi Ken,
I’m not sure if this is what you’re looking for, but it’s probably worth a look:
http://www.labsphere.com/productdetail.aspx?id=799&catid=
It’s a material called Spectralon, made by Labsphere. It comes in different shades, so they might have an 18% gray.
I know this is an old thread, but still a relevant question. If anyone else is currently looking for something similar, you should check out <http://store.rmimaging.com/digitalgraycard-100.aspx>
Ken Fleisher
