spectroscan calibration
I need to re calibrate my spectroscan table. I remember a long time ago n gretags website there was a chart you can download and print then calibrate the xy table. Does anyone have this target?
I think this is what you are looking for. I could only find it at the X-Rite site in the UK:
http://www.xrite.co.uk/documents/literature/gmb/en/SpectroScan_Test_Instructions_en.pdf
There is also a procedure for “calibrating the origin” which is used to calibrate the positions of white references on the SpectroScan. Email me directly and I can send that you if you wish. support(at)chromix.com
Thats it.
Thank you.
I believe this is something I need to do as well.
Can I please get it as well?
thank’s a lot
Boris
Hi Boris,
I’m glad to be able to help. I have sent a couple of pdf files to your email address.
