X-Rite's i1Diagnostics 4.1 Released
i1Diagnostics allows you to test your X-Rite measurement instrument functionality and update licenses on your device.
Use of this application by end users is recommended when problems are experienced with the measurement instrument.
i1Diagnostics creates a report which can be sent to X-Rite support for further investigation if problems persist.
Download Link: http://www.xrite.com/product_overview.aspx?ID=766&Action=support&SoftwareID=1453
The latest version of i1Diagnostics supports the following instruments:
i1Pro
i1Pro 2
i1iO
